Shuttle valve??
Old Apr 11, 2014 | 07:53 AM
jrod770's Avatar
Default Shuttle valve??
3 amigos are on. Abs amigo says fault 114, shuttle valve electric failure. After resetting with the amigo, 3 amigos will stay off for a little bit, but then come back on. After all my reading, I'm thining of replacing the shuttle valve unit and doing the re-wiring that is suggeted in the sticky for the shuttle valve. Does this sound like I'm on the right track? Thanks for your help.
Old Apr 11, 2014 | 08:59 AM
matt3502's Avatar
jrodd770-You are indeed on the right track. Get the falcon works kit, as it has the o-rings you should replace.
Old Apr 11, 2014 | 09:37 AM
drowssap's Avatar
You are indeed on the right track. x2
Old Apr 11, 2014 | 09:51 AM
ralphobell's Avatar
x2 on the Falconworks kit. Those orings fail and cause brake fluid to get on the shuttle valves and it eats the wiring away. As far as the bypass...not sure you will need it 100% of the time. But if your their you might as well.
Old Apr 11, 2014 | 10:22 AM
jrod770's Avatar
Was just sitting here looking at the Falconworks kit before you replied. I don't want to tear apart again, so I am going to do it all at once. Might at well just order and modify new shuttle valve and have it all ready to go before I even tear anything apart. Thanks for the inputs, i was just trying to make sure I was on the right page.
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
majrmike
Oct 9, 2007 03:13 PM
Different Drummer
Aug 7, 2006 09:28 AM
rovernbama
May 9, 2006 11:12 PM
