Shuttle valve?
Old Oct 10, 2016 | 02:43 PM
BraziliaNut's Avatar
Default Shuttle valve?
Hey Guys,
The 3 amigos have been lit on my truck for quite a while. Recently I purchased the iCarsoft ODBII reader (I think it's the i930 model) and was able to retrieve the "ABS shuttle valve electrical failure" code. I then got a new part from Atlantic British and replaced it (didn't see any leaks, the old valve was pretty clean and completely dry). I've cleared the codes but for my surprise and disappointment the 3 amigos came back up after a couple of miles. I've checked the codes and it gives me the same thing, shuttle valve failure! WTF? Now the 3 amigos keep coming back every now and then... Thoughts?
Oh, and do you guys know how I could test the old shuttle valve with a multi-meter?
Cheers
Old Oct 10, 2016 | 03:01 PM
Red5's Avatar
Check the updated link in the first post of this thread for a very detailed walk through.
https://landroverforums.com/forum/di...s-fault-26847/
I went with option B and have been fine for 2+ yrs.
Old Oct 10, 2016 | 04:56 PM
Wow, that's genius! And I realized I've seen an youtube video of the procedure at some point, but couldn't understand much (it's in French). But together with that detailed description on the thread, it all made sense. Here's the video:
Old Oct 10, 2016 | 05:02 PM
mln01's Avatar
It's a shame you spent the money on the shuttle valves when so very often the shuttle valve switch fault is caused by a failed circuit board in the modulator. Just go ahead and perform Option B as set out in the link above.
Old Oct 11, 2016 | 09:41 AM
jastutte's Avatar
I was getting the same fault code the OP was. For peace of mind I purchased and installed a new SVS and did the Option B fix. I figured why not do it all at once since I had it apart anyway.
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
majrmike
Oct 9, 2007 03:13 PM
Different Drummer
Aug 7, 2006 09:28 AM
rovernbama
May 9, 2006 11:12 PM
