Sloppy Steering
Old Jun 25, 2013 | 09:17 PM
coors's Avatar
Default Sloppy Steering
I'm trying to get to the bottom of my steering woes.
So far,I've replaced the steering bars front and rear with all four new greaseable tie rod ends. Steering rods and Steering damper are HD Terrafirma.
I have newer 265/75 BFG AT T/A KO's tires with a 2" TF MD lift
Truck has 180k miles on the clock.
I'm wondering on the highway (hard to keep a straight line). The alignment was set after the steering rods were installed. Alignment checks out fine.
The, wife doesn't like driving it says it "scary". I do notice I have a little play in the steering wheel. Could it be a bad steering box or ball joints?? How do I diagnose which is at fault?
Old Jun 25, 2013 | 09:23 PM
First, with anything over a 2" lift, your alignment is not fine, your caster is out and without also replacing your pan hard rod with an adjustable pan hard rod, your diff is now off center towards the drivers side.
I would also highly suggest you do a good inspection of all 6 of your trailing arm bushings as well as your radius arms.
Old Jun 25, 2013 | 09:26 PM
coors's Avatar
Whoops, thought I forgot something. New TF adjustable panhard rod was installed along the steering bars.
Excuse my ignorance. What's the difference between trailing arms and radius arms. Are trailing arms located in the rear of the truck? And radius arms located in the front of the truck?
Old Jun 25, 2013 | 09:31 PM
Yes, and the castor correction is what will keep you from tracking, but it requires castor correcting radius arms or the installation of a True Trac dif in the front which will always keep the steering centered so it won't track.
Old Jun 25, 2013 | 09:54 PM
Fivespddisco's Avatar
Check to see if
you're steering box has excessive play
The condition of the rear watts link bushings. If these are bad it will make the truck wonder down the road.
and as Mike Rad arm bushings maybe bad
Old Jun 25, 2013 | 09:56 PM
coors's Avatar
Good info. Thanks, guys.
Old Jun 26, 2013 | 08:51 AM
Shout if you need any help.
archaeology_student
Jun 8, 2013 11:04 AM
s10lowrider1994
Jan 7, 2013 09:41 PM
RjBu
Mar 1, 2011 10:31 AM
sloppyjoe
Sep 17, 2009 12:23 PM
84 GRANDSPORT
Feb 12, 2007 07:47 PM
