SLS problems
SLS problems
My SLS sometimes lowers to the bump stops a few seconds after the truck has been parked and shut off. When it lowers I can hear air escaping from the top of the rear drivers side air spring, leading me to believe that I have a leak and need new air springs. The thing that I don't understand is that half of the time it doesn't leak and the trucks air springs remain inflated. At times I have had the truck parked for a week and it has not leaked. If I had a leak wouldn't it always leak? I don't understand how it can leak just half of the time. I have been trying to sort out this problem for over a month but to no avail. Any help would be greatly appreciated.
Remember the SLS exhaust outlet vents into the frame right around the drivers rear wheel. Could be a sticking exhaust solenoid/valve. Would explain why it's intermittent and the sound you're hearing. You can pull the line out of the frame to see if that's where it's coming from.
smokin
09-06-2013 01:19 AM
DiscoIIBrandon
02-21-2011 03:09 PM
