Small Modification Write Ups + Index of Mods (Alex_M)
Old Apr 6, 2016 | 03:17 PM
  #111
Joemamma1954's Avatar
Charlie
Our Rovers do not have PCV valve, just the oil separator. It is considered closed, because both valve covers are getting vacuum, and I assume the ECM takes that into account in the fuel trim. Will investigate further.
Old Apr 6, 2016 | 07:09 PM
  #112
Charlie_V's Avatar
Default Oil consumption
When you guys talk about oil consumption are you including leaks or is that just oil that is consumed in combustion only?
Old Apr 6, 2016 | 09:25 PM
  #113
bcolins's Avatar
It Varies. My truck is burning it,...Alex's is leaking it.
Old Apr 7, 2016 | 09:56 AM
  #114
evoblade's Avatar
Do you have a part number or source for the oil separators? I have all of this stuff taken apart, so I might as well replace.
Old Apr 7, 2016 | 11:14 AM
  #115
Alex_M's Avatar
The separators themselves I do not. I've heard (but don't recall where) that there is an alternative Fram (I think) part number that will work and, if I'm remembering correctly, actually fits on the outside of the valve cover for easier future replacement.
Old Apr 7, 2016 | 01:19 PM
  #116
Charlie_V's Avatar
That's sounds like a good mod in its infancy.
Old Apr 7, 2016 | 06:31 PM
  #117
Alex_M's Avatar
Haha, well I know it's been done before. I (or someone) just needs to find it.
Old Apr 7, 2016 | 08:05 PM
  #118
Charlie_V's Avatar
A mini mod.
According to Bom2oo2 (from another thread):
Just leave the plastic piece out, & buy a fram FV237 PCV valve for $3-4, or a similar purelator part, & connect between existing metal tube & intake connection using same hose that you have (or a new one) ,, I did this a while back, after reading it in a tread, it's a very good mod, new pcv valve actually has a valve inside, so it won't get clogged easily, & cleaning it if necessary is very easy.
I found the Fram for about 4 dollars. It looks like this so you have to put it inline. Bay bling.
Interestingly, in that thread I learned that the 03/04 valve covers are different in regard to the oil separator setup. I didn't know that...
Here is the real thing. 6 bucks. For a piece of plastic.
Old Apr 7, 2016 | 09:27 PM
  #119
Alex_M's Avatar
That's it! You're magic, Charlie.
Old Apr 9, 2016 | 06:07 PM
  #120
bcolins's Avatar
A mini mod.
Will the Fram PCV work on a 2003 D2?
