Small Modification Write Ups + Index of Mods (Alex_M)
Old Feb 17, 2022 | 09:26 PM
  #141
Alex_M's Avatar
You're quite welcome. Mine were the same, and I need to finish out my other three wheels. I'll get to it eventually!
Old Feb 22, 2022 | 11:05 PM
  #142
gecko951's Avatar
Thanks Alex, this wiper mod made it so easy to go back to D2 arms. My only change was using socket cap screws and pressing out those metal tabs on the D2 arms with my socket (rather than pliers). I'm using Michelin High Performance All Season Wiper Blades from Walmart and they worked great in winter driving conditions.
Old Jan 4, 2023 | 09:09 AM
  #143
Alex_M's Avatar
Default Tire Size Fitment
Primary number will be the metric measurement for an 18" rim unless only one metric size is listed. First number inside parentheses is the imperial measurement, overall. Second inside the parentheses is the metric measurement for a 16" rim. Third number inside the parentheses is the measurement between opposite corners of the tire from a top-down view. This is the biggest measurement that matters because it takes tire width into account. If you know this measurement for your vehicle (at a given rim offset) then you can almost guarantee you're maximizing the use of your wheel well.
All fitment recommendations assume stock or near stock wheel offset.
Primary (First#, Second#, Third#)
Listed largest to smallest.
315/75r16 (34.6 x 12.4, 36.75 corner to corner) -
Minimum 3" lift required. Will rub radius arms without spacers. Body trimming required. More extreme trimming required with wheel spacers or wider offset wheels. Front bumper trimming or replacement necessary. Spare carrier modification necessary even after flip.
285/75r18 (34.8 x 11.2, 36.56 corner to corner) - Minimum 3" lift required. Will rub radius arms without spacers. Body trimming required. More extreme trimming required with wheel spacers or wider offset wheels. Front bumper trimming or replacement necessary. Spare carrier modification necessary even after flip.
285/75r16 (32.8 x 11.2, 34.7 corner to corner) - Minimum 2" lift required. May rub radius arms at full lock and rear of fender well at full flex, vehicle dependent. Spare carrier flip necessary. Front bumper trimming or replacement necessary.
275/70r18 (33.2 x 10.8, 34.9 corner to corner) - Minimum 2" lift required. May rub radius arms at full lock and rear of fender well at full flex,vehicle dependent. Spare carrier flip necessary. Front bumper trimming or replacement necessary.
245/75r18 (32.5 x 9.6, 245/85r16. 33.89 corner to corner) - Rubbing likely with no lift except in outlier cases, recommend 2" lift to guarantee no rubbing. Spare carrier flip necessary.
275/65r18 (32.1 x 10.8, 275/75r16, 33.87 corner to corner) - I have run a used set of these with no lift, no rubbing. I believe this is an outlier case, recommend 2" lift to guarantee no rubbing. Spare carrier flip necessary.
235/75r18 (31.8 X 9.3, 235/85r16, 33.13 corner to corner) - No lift possible with no or minor rubbing. Safe choice with no lift if you do not mind chance of very minor rubbing, 2" lift recommended to guarantee no rubbing. Spare carrier flip necessary.
265/65r18s (31.6 x 10.4, 265/75r16, 33.27 corner to corner) - I have run these with no lift and no rubbing. Some report minor rubbing. Safe choice with no lift if you do not mind chance of very minor rubbing, 2" lift recommended to guarantee no rubbing. Spare carrier flip necessary.
255/65r18 (31.1 x 10, 255/75r18, 32.67 corner to corner) - Almost definitely no rubbing at stock height except possibly in extreme outlier cases. Spare carrier flip may be necessary, vehicle dependent.
265/60r18 (30.5 x 10.5, 265/70r16, 32.25 corner to corner) - Stock suspension, no reported rubbing. Spare carrier flip not necessary.
245/65r18 (30.5 x 9.6, 245/75r16, 31.98 corner to corner - Stock suspension, no rubbing. Spare carrier flip not necessary.
If you'd like to input your own tire sizes and do the calculations, use this tire size calculator and this triangle calculator. Make sure triangle angle is set to 90 degrees, input imperial width and height to get corner to corner measurement as the "third side" of the triangle.
Old Jan 9, 2025 | 11:45 PM
  #144
CharminULTRA's Avatar
Hi Alex - What is this in one of your repair photos? Is this some sort of filter you built for the cabin air intake?
Old Feb 2, 2025 | 05:41 PM
  #145
dmueller's Avatar
@Alex_M can you please advise as to how you built this intake cover?
Old Mar 3, 2025 | 10:39 PM
  #146
Alex_M's Avatar
I haven't been online in a while, so apologies on the delayed answer! This was a long time ago, but all that was is an old broken air cleaner lid. I cut it roughly in half. Maybe 1/3 cut off of it, I don't recall exactly - it was a decade ago now. A far as attachment - I think that I just stuck a screw in either side thru the plastic intake, and it was sealed with some black silicon around the bottom. No filter.
Old Mar 4, 2025 | 08:37 AM
  #147
redrover75's Avatar
That would certainly keep the squirrels out. Last winter twice I had to clean the acorns out of the blow motor. The squirrel cage. I ended up putting chicken wire over the intake, seems to have fixed it.
FlyFishing701
Apr 20, 2022 06:01 AM
LR03NJ
Feb 8, 2017 06:54 AM
Chrisinhouston
Apr 10, 2014 08:49 PM
Tomahawk
Appearance & Camping Set Ups
Oct 4, 2013 04:24 AM
rj95lss
Jan 26, 2010 11:07 AM
