Small Modification Write Ups + Index of Mods (Alex_M)
#123
Reverse lights that will blind you ($22)
Very simple. These are two LED light bars, $11 each shipped, and they will splice right into the factory wiring. There are no relays needed because the wiring is the same gauge as the factory wiring. They are not getting warm at all and they work 10x better than the factory reverse lights with LED bulbs.
Link to lights
Link to lights
Thanks Alex for the tip.
#124
#126
#127
The 03-04 version has a restrictor disc pressed in to the vent tube. The baffle is removable, but you have to pull the tube out of the valve cover to get to it from the bottom. You can soak it in carburetor cleaner to dissolve the baked in carbon to get it out in one piece, but I usually just drill them out.
#129
I don't think the o ring is critical. . Mine don't have them and don't leak. But then I may have torqued mine more than 6 pounds or whatever rave calls for. I did the Pontiac mod. Major air improvement for about 50 bucks. I'll post it. I've been leeching your ideas for over a year so it's only fair.
