small oil leak. big deal I know.
Old Sep 2, 2014 | 11:12 AM
Pjpax's Avatar
Default small oil leak. big deal I know.
I've had my disco 2 for a couple months now. I've changed the oil regularly and replaced the oil pan gasket and the oil filter gasket. For some reason there is a small oil leak where the oil pan meets the transmission I believe. There is a small circular plate with three 8mm bolts on it and after every time I drive it there is always three little droplets of oil on the tips of the bolts and covering the oil pan from blowing around (I assume). They may be stripped but I really hope not.
Attached Thumbnails small oil leak. big deal I know.-20140902_100128.jpg   small oil leak. big deal I know.-20140902_100116.jpg
Old Sep 2, 2014 | 11:22 AM
drowssap's Avatar
have you checked the back of the valve covers yet? they tend to leak down the back of the engine.
if the oil is coming from inside that cover you have a leaking rear main seal
COBRA
May 27, 2013 02:17 PM
MCKEAG
Mar 24, 2011 11:08 AM
reauxver311
Oct 18, 2010 10:53 PM
00&04 Disco
Sep 10, 2009 10:47 AM
soonerswin
Aug 22, 2007 09:38 AM
