Solid Aftermarket Lugs?
Old Jul 6, 2021 | 07:41 AM
discoinfernoOSV's Avatar
Default Solid Aftermarket Lugs?
I'm having what I can only imagine is the same dilemma many disco owners have had. The lugs on the new (to me) disco were torn up and have resulted in many of the lugs needing to be replaced. I have 5 OEM coming in today so I can get the wheels back on after a brake job, but I have just found these (
Veritek solid lugs Veritek solid lugs
) on amazon for a good price. I like the idea of switching to a solid lug so the caps are no longer an issue. I'm a bit concerned about these because they seem to be smaller (22mm vs 27mm) and am wondering if anyone has used these. I've seen a few threads with people buying solid lugs off ebay, so I'm going to look there as well.
Old Jul 6, 2021 | 08:35 AM
mollusc's Avatar
I have solid lugs, but they're the same size as the capped originals. They work just fine, and no more hassles with the original sheaths. They're plated, so if you use them too much (or, really, if you use them at all) you will break through the coating and they will start to oxidise a bit.
Andy_R
Oct 14, 2018 03:23 PM
CoachTodd
Apr 19, 2017 07:14 AM
ggushee
Apr 16, 2015 08:54 AM
Chrisinhouston
Aug 13, 2013 10:18 AM
spiderfreak80
May 13, 2012 02:51 AM
