Sounds like valves tapping??!!
Old Oct 11, 2007 | 10:14 AM
  #21
98roverguy's Avatar
Default RE: Sounds like valves tapping??!!
I just got a mini catalog from them and they are on sale this month.
Old Oct 11, 2007 | 10:29 AM
  #22
Yell when you are ready to do the flush and I'll give you a list of stuff to get and you can flush the engine, and do an induction cleaning at the same time.
Old Oct 11, 2007 | 06:19 PM
  #23
DeepBlueWater's Avatar
From hollis's description - My 2003 Disco had the same annoying tapping noise. I performed the ATF engine flush as descibed,replaced the oil / filter this afternoon and wa-la. It worked... no more ticking noise. Engine sounds smoooooooth.
Curious about the induction cleaning?
Thank youeveryone for the advise- very appreciated.
MWmG
Old Oct 12, 2007 | 12:07 AM
  #24
Willie 00D2's Avatar
You might want to run some Land Rover fuel system cleaner, its suposedto help remove carbon from the valves. I heard rovers have close tolerances for their valve stem to guides. Carbon build up can make the exhuast valves stick in the guides. I was also told not run any other types of fuel system cleaners in the LR. May not cure your ticking but it should help keep your engine a little cleaner.
Willie
Old Oct 12, 2007 | 03:17 AM
  #25
hollis's Avatar
I am probably going to do the flush this weekend... Induction cleaning also and I found the Seafoam thread..?? Ill take that list if you got it!! Thanks a bunch disco mike!
Old Oct 12, 2007 | 03:24 AM
  #26
hollis's Avatar
so the more I keep reading the more questions I get! lol I think I should drop the oil pan to clean the pickup?? I highly doubt it has been done ever and I found a thread that says that it will clog after a engine flush.. Any other areas to service while I am at it??
Old Oct 12, 2007 | 08:50 AM
  #27
If your pick up tube had clogged, you would have a oil pressure light on all the time, don't worry about it, you'll be fine.
ruffram
Sep 1, 2011 08:15 PM
LRXD
Sep 13, 2006 02:24 PM
2k2wranglerx
Mar 12, 2006 06:44 PM
jmerrill
Mar 5, 2006 01:38 PM
Rovercountry
Oct 7, 2005 09:00 PM
