Spare tire swingaway for Greg Davis bumper?
Old Jan 15, 2018 | 06:03 PM
Good site thanks for that link
Old Jan 15, 2018 | 07:01 PM
Jeff Blake's Avatar
Good info, thanks. Looking at parts helps me wrap my head around what to do
Leaning towards ordering it from a fab shop, such as this one Swing Out Tire Carrier
and then having a welder doing the install. I need to research more options on whats out there first.
I'm thinking to have it swing open to the driver side, with a fold down table on the backside. Will compliment my cargo door fold down table nicely. The extra tabletop space will be good to have, as the coleman stove takes up 75% of my door table. Going to pass on the hi-lift and jerry can options.
Old Mar 21, 2018 | 10:13 AM
JohnHZ3's Avatar
I have been planning on doing this for a few years and finally got around to it thanks in part to this thread. The rear door was already damaged prior to my ownership and was difficult to close. The tire is 315/75R16 which is obviously way too heavy to be mounted to the door. I looked into all the parts offered for sale but decided none were exactly what I wanted. I liked the bushings of the Iron Pig spindle and the dual shear bracket of the Comp 4x4 version. I also liked the idea of a sleeve welded into the bumper rather than welding the spindle in place. This will allow for easy replacement or removal of the spindle in the unlikely event in gets damaged.
After measuring numerous times I drilled through the top and bottom of the bumper using a 2" hole saw. Then using an angle grinder with a cutoff wheel I connected the two circular cuts. A piece of 2" OD 1-1/2" ID tubing was tack welded as squarely as possible into the cutout. The hinge pin is 1-1/2" diameter steel. The carrier pivot is 2-1/4" OD 1-3/4" ID tubing with bronze bushings inserted (which were removed and replaced with new ones after welding). The frame is constructed of 3" x 1-1/2" (1/8 wall) tubing and 1-1/2" x 1-1/2" (1/8 wall) tubing. I added a dual-shear bracket to the pivot point to increase the rigidity. I modified and reused the mounting bracket which had been installed on the door for the rim mounting. After welding and mounting the carrier frame, I was disappointed by the amount of flex/bounce with the tire installed. All the flex was in the bumper itself and not the carrier or hinge. I ended up making an additional bracket, which mounts in the stock location on the door, to anchor the carrier to the door. It also doubles as the antennae mount. All the weight is still on the bumper. Everywhere a structural bolt mounts to the bumper I installed a rivet nut insert for added strength and grade 8 hardware was used. I am pleased with the appearance and strength. Having to loosen 3 screw-in handles is a bit cumbersome to open the carrier but ultimately I decided it was more important to have it securely attached.
Attached Thumbnails Spare tire swingaway for Greg Davis bumper?-bumper-cutout.jpg   Spare tire swingaway for Greg Davis bumper?-sleeve-bumper.jpg   Spare tire swingaway for Greg Davis bumper?-hinge-mockup.jpg   Spare tire swingaway for Greg Davis bumper?-back-no-tire.jpg   Spare tire swingaway for Greg Davis bumper?-back.jpg
Old Mar 21, 2018 | 11:09 AM
Sixpack577's Avatar
That looks really good.
Any full pics from the side?
Old Mar 21, 2018 | 11:33 AM
JohnHZ3's Avatar
Thanks. I will post a side view when I get home later.
Old Mar 21, 2018 | 10:02 PM
JohnHZ3's Avatar
Side views as requested
Attached Thumbnails Spare tire swingaway for Greg Davis bumper?-side1.jpg   Spare tire swingaway for Greg Davis bumper?-side2.jpg
Old Mar 21, 2018 | 10:09 PM
Alex_M's Avatar
Are those Cragar rims?! I've been trying to figure out for years if Cragar 15s would clear the factory brakes!
Install looks awesome by the way.
Originally Posted by JohnHZ3
I have been planning on doing this for a few years and finally got around to it thanks in part to this thread. The rear door was already damaged prior to my ownership and was difficult to close. The tire is 315/75R15 which is obviously way too heavy to be mounted to the door. I looked into all the parts offered for sale but decided none were exactly what I wanted. I liked the bushings of the Iron Pig spindle and the dual shear bracket of the Comp 4x4 version. I also liked the idea of a sleeve welded into the bumper rather than welding the spindle in place. This will allow for easy replacement or removal of the spindle in the unlikely event in gets damaged.
Old Mar 21, 2018 | 10:46 PM
JohnHZ3's Avatar
The rims are 16". The previous owner told me he sourced them through Lucky8 about 5 years ago. Thanks for the kind words.
Old Mar 21, 2018 | 11:59 PM
Alex_M's Avatar
Ah, bummer. That makes those tires 35s. Would you care to throw up some more pictures of your rig? Maybe make a post detailing lift, gears, axles, pros and cons, etc? I'd love at least some pictures. I've been planning on 35s for a while.
Old Mar 22, 2018 | 06:58 AM
Sixpack577's Avatar
I'de like more pics and info on it too.
