Spark only on 1 coil
Old Jan 2, 2023 | 07:40 PM
Shlads's Avatar
5th Gear
Default Spark only on 1 coil
I only have spark on 1 coil. I have power to both coils. I've switched coils didn't make a difference. So it's not the coil. I suspect ecm but don't know how to determine that. Where can I get a wiring diagram for the coil wiring.
Old Jan 3, 2023 | 02:05 AM
XRAD's Avatar
download RAVE :
https://discoii.wordpress.com/resources/
Old Jan 9, 2023 | 06:20 PM
Shlads's Avatar
5th Gear
No one has any ideas??
Old Jan 9, 2023 | 06:57 PM
Best4x4's Avatar
Don't quote me on this, but if I remember correctly the coils get their power thru the fuse box under the dash.
Old Jan 9, 2023 | 07:02 PM
Shlads's Avatar
5th Gear
I have power to the coil, but I also have 4v on the signal wires.
Old Jan 14, 2023 | 06:58 AM
Shlads's Avatar
5th Gear
Anybody ever chany ECU? If so what was the reasoning?
Old Jan 14, 2023 | 09:27 PM
mollusc's Avatar
Plenty of threads on here regarding changing the ECU. You need to change the instrument cluster and the BCU as well, since they all sync together. Reasons I have read include water damage and other types of issue that caused a whole range of unusual errors.
Old Jan 15, 2023 | 12:10 PM
XRAD's Avatar
fly wheel (crank) or cam sensor?
slater1967
Range Rover P38 (2nd Gen)
Jan 3, 2023 11:55 AM
Tommyblack97
Feb 27, 2021 05:00 PM
DiscoRover007
Jul 12, 2012 09:28 PM
hendoc3
Jul 19, 2007 06:02 PM
alpinab7
Aug 2, 2006 11:36 PM
