Spark plug removal quick question
Old Apr 9, 2010 | 09:47 AM
04discomw's Avatar
Default Spark plug removal quick question
Hello all,
I'm replacing my sparks plugs this weekend and was wondering if anyone could give me heads up on if I have to remove anything to access/remove all 8 plugs. The area seems kinda tight. thanks.
Old Apr 9, 2010 | 09:54 AM
What plugs are you installing, how many miles on your engine and will you also be replacing the plug wires?
One thing you can do is remove the air intake hose from the filter to the t/body to give you a better shot at the plugs, us a 3/8 th." drive and don't forget to put some anti-sieze on the plug threads before installing.
Old Apr 9, 2010 | 10:06 AM
04discomw's Avatar
I haven't purchased the plugs yet, but heard good things about Bosch. So I'll probably pick those up. No, I'm not replacing the wires at this time, but plan to in the near future. 84,000 miles. Thanks for the pointers Mike.
Old Apr 9, 2010 | 10:09 AM
d2luvr's Avatar
If you still have the original wires they are getting pretty crispy by now.
Old Apr 9, 2010 | 10:26 AM
04discomw's Avatar
I'm not sure if the wires have been replaced or not because I just bought the car 5 months ago. Is there a way to see if the original wires have been replaced just by looking at the markings or labels on the wire, or even the color? Assuming the PO replaced with aftermarket wires, not the same exact wires as factory. thanks.
Old Apr 9, 2010 | 10:45 AM
hilltoppersx's Avatar
the OME wires are grey 7mm wires. use 8MM magnecor wires from Apex performance and Bosch +4 plat plugs. total cost around $100.
Old Apr 9, 2010 | 01:10 PM
antichrist's Avatar
If you have compressed air access, back off the plugs a turn then blow out the plug well with air so if there is any debris it doesn't fall in to the engine, or get knocked in when reinstalling the plugs.
Be careful what anti-seize you use, not all are as electrically conductive as others.
I've been using Bostic Never-Seez for about 30 years and swear by it.
bootzilla
Oct 9, 2012 03:03 AM
primey
Oct 26, 2011 07:24 PM
steveo2000
Sep 11, 2011 10:19 AM
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
