Spark Plug Wires + Plugs + Coil + Valve Cover Gasket
Old Mar 31, 2020 | 12:10 AM
GoRoll's Avatar
Originally Posted by boston4
Are coil packs a wear items w/ a recommended replacement interval on these trucks? Some people say 100k but Id guess most don’t bother considering them as a scheduled maintenance item (at least I haven’t on previous vehicles).
I bought new plugs and wires to install next weekend - since I don’t have SAI, this should be a relatively quick job if I don’t do coil packs as well. However, probably makes sense to do all three components at once if the coil packs are something that should really be replaced.
I bought the truck at 110K. I'm already doing the plugs and wires, might as well. And I see the valve cover leaking as well. I’m just going to do all the things that needs to be changed while I’m here.
Old Mar 31, 2020 | 04:20 PM
GoRoll's Avatar
What is the PCV mod?
Is this it?
Current engine bay...
edit: I think I found my answer, going to find that part. I'm guessing I need two, one for intake and one for the valve cover.
https://landroverforums.com/forum/di...install-92942/
Old Mar 31, 2020 | 04:25 PM
Best4x4's Avatar
Sticky on the PCV Mod is above the D2 Forum threads. You replace the plastic 14mm black nipple just to the left of your finger. Remove black hose from the valve cover, unthread the black plastic nipple using a 14mm box wrench. Install the FV308 in it's place. Then follow the black hose down to the valve cover and remove the spiral plastic baffle.
Old Mar 31, 2020 | 04:27 PM
boston4's Avatar
It’s the hose to the left of your finger - undo the hose clamp, unscrew the plastic piece, screw in the new part, reattach the hose. If you have a 99-02 4L, then pull the other end of the hose off the valve cover and use needlenose pliars to pull out the oil separater, and then slide the hose back on. Takes all of 2 mins.
Old Mar 31, 2020 | 04:40 PM
GoRoll's Avatar
1. Wires
2. Plug
3. Coils
4. Valve Cover Gasket
5. PCV mod...
Anything else I should do while I'm here...
So far, this virus thing is giving me time that I didn't have before.
Old Mar 31, 2020 | 04:42 PM
boston4's Avatar
Also - you only need one PCV valve for the fitting at the top front of the (edit: intake, not valve cover). On the far end of the hose (on the valve cover toward the firewall) you remove the separator and refit the hose and you're done. If you have an 03-04 with the 4.6L you'll need a drill as they changed the way the separator was installed.
Old Mar 31, 2020 | 05:12 PM
GoRoll's Avatar
Also - you only need one PCV valve for the fitting at the top front of the valve cover. On the far end of the hose (toward the firewall) you remove the separator and refit the hose and you're done. If you have an 03-04 with the 4.6L you'll need a drill as they changed the way the separator was installed.
i have the 4.0 but the hose I see only on top of the valve cover that goes back to the intake. I can't see the other hose on the back of the valve cover...
Do you have any photo?
Old Mar 31, 2020 | 05:15 PM
GoRoll's Avatar
Left
Right
Old Mar 31, 2020 | 05:27 PM
boston4's Avatar
See circled fittings. It’s a really short hose. I mistyped before - the PCV valve goes on the intake - you can see it's a brand new part in the first pic.
On the valve cover side, you pull off the hose, pull out the separator, and refit the hose:
Old Mar 31, 2020 | 07:14 PM
GoRoll's Avatar
thank you. My buddy will be doing it for me since he works at the dealer and currently has lots of time and will be able to do this in a day.
