Split oil pressure sensor port
How bad is the split? How long is it? That port has 50 psi on it. The sensor is sealed with a washer, very end of the port. If it not too long you could use silicone on the threads and it might seal, cost almost nothing to try. You cold try job weld, but given the pressure I doubt it will work. You can remove front cover and have it welded, or replace it.
0304Disco
05-19-2011 03:18 PM
