Split oil pressure sensor port
Old Oct 13, 2019 | 05:34 AM
Equinut's Avatar
7th Gear
Default Split oil pressure sensor port
During the course of identifying & fixing a total engine oil pressure loss the pressure sensor was replaced. Oil is now leaking from a split in the port. Advice please on how to repair.
Old Oct 13, 2019 | 05:38 PM
Extinct's Avatar
How bad is the split? How long is it? That port has 50 psi on it. The sensor is sealed with a washer, very end of the port. If it not too long you could use silicone on the threads and it might seal, cost almost nothing to try. You cold try job weld, but given the pressure I doubt it will work. You can remove front cover and have it welded, or replace it.
Old Oct 27, 2019 | 05:47 AM
Equinut's Avatar
7th Gear
Default Pressure senor port splitting
Having split ports on 2 oil coolers, the second with only light spanner pressure, the 3rd has been fitted with its sensor untouched! If it's ever necessary to replace a sensor it will be finger-tight only with silicone sealer to secure it!!
Old Oct 28, 2019 | 10:48 AM
Brandon318's Avatar
Used front covers on eBay are super affordable. I would go ahead and replace it. Not too terribly involved. Good opportunity to check in on the timing chain and other various bits behind it.
markdeg
Apr 22, 2019 05:33 AM
escott16
Jun 13, 2018 04:14 PM
0304Disco
May 19, 2011 03:18 PM
ArmyKen
Apr 10, 2011 09:16 PM
cathaan
Mar 12, 2010 09:45 AM
