Spring choice for offroad bumpers
Old Feb 7, 2018 | 10:03 AM
Sandman614's Avatar
Originally Posted by Best4x4
With just bumpers a medium duty spring will work. HD would be a good idea with a winch or more weight in the rear. “If” your D2 has the original springs I would not just slap a spacer in to make up for the weight. The ride is going to be terrible due to the springs already being saggy/sprung, and the added weight is just going to make it ride/drive like crap.
Right now I'm leaning towards the standard (20mm lift) springs, figuring if the weight of the bumpers bring it down it should still sit just over stock height. A buddy of mine made the comment of "Seems like you need a happy medium and it's not there.. Either not quite enough or too much.. Where's that 30mm Coil when ya need it"
Old Feb 7, 2018 | 11:00 AM
alpinacsi's Avatar
There is also a big difference in the steel bumpers out there: some are not much heavier than stock. Some have added nerf bars and brush guards and some are very basic. Sounds like you need standard replacement and if you need to balance out the height: there are different spring cushions and spacers available to make those adjustments.
There are a few suppliers here that offer good deals on kits and provide excellent insight on what might be necessary for your application. One advertises in the classified section with daily deals and will often list a 2" medium duty kit at an excellent price.
Old Feb 7, 2018 | 02:24 PM
Alex_M's Avatar
As Best said, spacers are not the right way to correct for added weight. You need stiffer springs; not longer ones.
Old Feb 7, 2018 | 04:14 PM
Honesty if you are adding those basic britpart front and rear steel bumpers get new stock springs.
Old Feb 9, 2018 | 07:57 AM
Sandman614's Avatar
This reinforces my thought of getting the Standard lift(20mm) springs and if the weight sags them it would be back to around stock height.
I am a big supporter of real suspension lifts.
cybercop
Apr 22, 2015 02:14 PM
yzblue125
Dec 30, 2010 07:46 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
KBW
Mar 24, 2009 06:28 PM
derrickalda
Appearance & Camping Set Ups
May 9, 2008 12:08 AM
