Springs or spacers
Old Apr 2, 2021 | 07:03 PM
Big Jim Swade's Avatar
The ARB "light duty" are 1.5" lift also and probably rides closest to stock.
Old Apr 2, 2021 | 07:22 PM
Alex_M's Avatar
There's really not much of anything wrong with spacers. If you're doing 90% street driving and your stock suspension is performing how you want it to then spacers will get you 100% there. The only real reason to use lift springs is either because you do off road the truck and you want the off road performance, or because you need to replace your springs anyway (one is broken, excessive sagging causing uneven ride height, or you need increased capacity).
Even on my rigs, which I do off road, I cheap out and put together my own lift. Extra set of stock rear springs in the front, make my own 3" or 4" blocks for the rear, and then modifying the shock mounts so I still get full travel out of my suspension. I'd eventually like to upgrade the rear springs on the rigs that see a lot of off road action, but it works really well in the mean time.
Nothing wrong with spacers, even if your suspension is sagged as long as you are happy with your ride quality, I wouldn't be afraid of them.
Old Apr 3, 2021 | 07:37 AM
mollusc's Avatar
Originally Posted by ahab
Do you have med duty in the rear or stock? I am thinking of doing something to the 03 and a bumper/bull bar is near the top of the list. I'm lining up a set of OME MD springs but perhaps I should be considering HDs
I believe I have regular weight springs in the rear (TerraFirma replacements, not originals or OEM). If I ever replace the rear bumper then I'll upgrade them.
yardpro
Dec 18, 2018 02:01 AM
ycc456
Apr 2, 2014 12:38 PM
ZGPhoto
Jul 1, 2013 02:28 PM
Draayer
Aug 29, 2011 03:47 PM
malmberg
May 13, 2009 08:17 PM
