Squeaking New front driveshaft
Old Nov 18, 2016 | 03:02 PM
huggi's Avatar
Default Squeaking New front driveshaft
Hello all, got a new drive shaft from a well known vendor. Put it on and I get a very slight squeak (small bird chirp/squeak) when slowing down, like stopping at a light or rolling though a parking lot. No other noises during acceleration etc. Any suggestions what it could be? Rather not pull the drive shaft and return it, too much work. I greased all the zerks, though the front most one (angled at 45* within the joint) I can't get a good seal on the zerk, so it's squeezing out at the zerk, on contacting the company they said the joints come pregreased. Anywho, ideas what it could be. How to fix it without having to return?
Thanks
Old Nov 18, 2016 | 03:09 PM
ShaggySE7's Avatar
Centering ball needs grease? There is a pin hole that is very hard to get to. I bought a needle fitting and bent it so I could grease mine. You'll have to remove the shaft. Good luck!
Old Nov 18, 2016 | 03:31 PM
huggi's Avatar
Where is the centering ball, front or back of the drive shaft?
Old Nov 19, 2016 | 05:23 AM
ShaggySE7's Avatar
It's in the back between the two u joints in the double cardon. there are some photos on here somewhere. Search for centering ball
Old Nov 19, 2016 | 07:59 AM
coors's Avatar
Thanks
are you certain it's the ds and not your brake pads squeaking? I had a similar experience I was able to identify the pads as root cause by "riding" and pulsing the brakes.
Old Nov 19, 2016 | 10:56 AM
jastutte's Avatar
did you grease it before or after you installed it?
Old Nov 19, 2016 | 12:12 PM
huggi's Avatar
Yea greased, before and after.... Only zerk I can't get to is within the forward most joint, comes out from the middle of the joint at a 45 degree angle. I ordered a needle tip for my greasy gun - hope it works. I'm not sure if by DS has a zerk fitting for the centering ball, I'll check with the manufacturer.
robert.juric
Nov 3, 2022 06:08 PM
rooooney
Feb 23, 2016 05:34 PM
wittingsun
Nov 1, 2015 06:03 AM
mstrachan1986
Sep 16, 2014 12:10 PM
troy5174
Sep 1, 2013 10:04 AM
