SRS Issue - Removing Airbag Cover Torx Bolts
The SRS light has come on intermittently. The Nanocom says there is a ground short to the airbag module. Going to check the rotary coupler and the electrical connectors.
I need to remove the steering wheel cover. RAVE says to remove the two Torx bolts at the back of the steering wheel. Unfortunately, there is no space for my head to take a peek at the Torx bolt heads.
I tried to loosen it with a few Torx wrench sizes. The wrenches do not seem to catch on to the Torx slots in the bolts. I hate to force it and strip the heads of the bolt. Does anyone know the specific Torx size of these 2 bolts (see attached pic).
Thanks in advance!
Thanks in advance!
You may need a set like these Mannesmann T Handle Wrench SET 16 PCS Torx AND Ballpoint HEX KEY Wrench SET | eBay
or a socket set type with long torx rods.
Don't forget to disconnect the battery first and allow the specified time before you attack the airbag. Also treat it gently, very gently, you don't want a facefull of metal - now do you![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
I have removed mine a few times. It is either a regular t27 or a t30. I use "key" style torx wrenches, they fit into the holes in the back of the steering wheel well. You may also want to think about replacing the clockspring. Mine went bad and caused all sorts of issues with the airbag light, horns, and cruise control not working right.
