SRS light after gasket change
Old Mar 27, 2009 | 04:43 PM
cplthomas's Avatar
Default SRS light after gasket change
I got an SRS light on now. Just changed out the head gasket. Among other things still wrong this is one that I can't figure out. Any thoughts?
96 disco.
Old Mar 27, 2009 | 04:47 PM
Most likely you have a low voltage fault caused by unhooking the battery.
You can only clear the codes by using the proper scanner and going thru the ecu, an engine scanner won't cut it.
Old Mar 27, 2009 | 05:42 PM
cplthomas's Avatar
So, my SRS system is good, it just needs to be reset huh?
Old Mar 27, 2009 | 05:55 PM
Didn't say that exactly, should be good, but it will cost you dearly to get it reset.
Old Mar 27, 2009 | 06:06 PM
cplthomas's Avatar
Uggh. Thats what I was afraid of. The nearest stealership is over 3 hours away, I am hoping to find a decent import mech around that might be able to help me with the resetting and such. My obd2 scanner doesnt even register it...
Old Mar 28, 2009 | 07:04 AM
Look around, they are out there and charge less then the dealers.
Old Mar 28, 2009 | 03:01 PM
mwindth's Avatar
96 disco.
Hey 96,
I'm pretty sure the SRS light has to do with your seat belt restraints. When my SRS light came on, I simply looked under the drivers seat from the rear, found a clear plug that is held in by a velcro pouch, put some di-electric grease on it, plugged it back in and into the velcro pouch and the light turned off.
I hope this helps.
Old Mar 29, 2009 | 09:49 AM
cplthomas's Avatar
Thanks! I will try it.
DiscoJonny
Apr 28, 2012 07:21 PM
RoveringAgain
May 20, 2009 07:40 PM
Willie 00D2
Oct 27, 2008 12:28 AM
mfryburg
Oct 19, 2008 10:38 AM
