Starnge short noise, just after starting the car
Old Jan 20, 2012 | 08:21 AM
hhalimi's Avatar
Default Starnge short noise, just after starting the car
My 04 Disco is making a starnge noise, just after the car starts, when I let the key go (from kranking position), it lasts only a second or so, it is difficult to descibe, a buzzing sound will probably descibe it best. It feels as if it is comming from under the steering/dash. Any idea what it could be?
Old Jan 20, 2012 | 08:44 AM
Could be your starter hanging up for a second, if coming from under the steering column could be the small fan for the a/c temp sensor making noise.
Old Jan 20, 2012 | 09:06 AM
hhalimi's Avatar
Doesn't sound like the starter continuing to crank. Any ways to check if it is the AC fan?
Old Jan 20, 2012 | 10:14 AM
discotheque's Avatar
Pretty sure I have the same problem. It sounds to me like the brake pedal. Try pumping it twice and hold down hard before you crank it and the sound should be atleast muffled.
Old Jan 20, 2012 | 11:06 AM
Unplug fuses for suspect device. If does this on first start of the day, could be the SAI pump, they run for a short time after a cold start, when failing can sound like a hair dryer.
loomy123
Jan 4, 2014 09:09 PM
marjac
Jul 4, 2012 09:12 AM
WBMIAMI
Mar 3, 2012 03:24 PM
rjennings
Aug 31, 2008 08:15 AM
