Started with a P0305 and now P0300
Okay here we go. My 2004 D2 has 88k on it. Changed the plugs when I did Disco Mikes service. New 8mm Magacor went in the also. All of a sudden yesterday it started to stutter up a hill the CEL came on and then my ultra guage started chirping. Came up with a P0305 code. I pulled the plug (bosch plat 4's). It looked okay, a little whitish. Wanted to replace just the one, ended up replacing all becasue my local shops did not carry. Replace it with Bosch platinums.
Same problem is happening (occurs under load), now it is throwing P0305, and P0300. Any thoughts from the esteemed panel out there?
Will check as soon as I get a chance Mike. One thing I forgot to mention was that about 4 months ago, it threw a code for lean engine in that bank of cylinders. Only happened a couple of times, then went away. As far as I know, these are the original O2 sensors. Correlation there somewhere?
I had a similar issue few years ago on my dads truck. Think the exact same codes.
My first coarse of action was like what you've done, swapping plugs/wires to see if the miss followed. It didn't.
I was then going to start looking at the coil packs and injectors, but then the P0300 showed up and made me scratch my head.
As a last ditch effort, I dumped some injector cleaner in the tank. After 2 treatments of the stuff, the codes have been gone ever since. I think maybe it was a bad tank of gas.
So, you can always give that a try.
As for the lean codes, if they continue to pop up, first thing i would check for are vacuum leaks
The bad gas is an interesting idea. I filled up at Costco the other day, perhaps that is it. I put a can of Seafoam in the tank so we will see if that helps to clear it up. Bit of a catch 22, as I am reluctant to drive the car very far, so emptying the tank may take a while. The lean codes have not reappeared for a long time.
fund247
02-16-2013 02:22 PM
EVN137
02-25-2012 02:05 PM
