Steering box install....
Old Jul 2, 2016 | 02:10 PM
dtmbinb's Avatar
Default Steering box install....
New member here. Thanks for all the valuable knowledge I've already acquired from the forum. My steering has a bunch of play and doesn't return to center. I'm replacing my steering box with a good low mileage one. Anything else I need for the install other than new fluid? Any gaskets or seals? Thanks in advance!
Old Jul 2, 2016 | 09:25 PM
disc oh no's Avatar
You shouldn't need any seals or anything. It's a pretty straightforward job on most trucks. I'm not sure about Rovers?? I don't think I've ever done one.
Old Jul 2, 2016 | 10:01 PM
number9's Avatar
Should replace pipe o-rings. LH lower illustration of pdf.
File Type: pdf
Old Jul 2, 2016 | 10:39 PM
dtmbinb's Avatar
Originally Posted by number9
Should replace pipe o-rings. LH upper illustration of pdf.
Thanks! I don't need to remove the coolant rail in the pdf, do I? Is that illustration for a different repair?
Old Jul 2, 2016 | 11:01 PM
number9's Avatar
Yes, mistakenly attached the diesel version. Edited previous one and has correct page.
Old Jul 2, 2016 | 11:14 PM
dtmbinb's Avatar
Thanks again! You had me confused for a minute. Cheers!
johnkbl
Sep 21, 2023 06:17 AM
texci77
Jun 6, 2012 01:24 PM
DiscoBritney
Dec 19, 2011 06:24 PM
losinov
Mar 21, 2011 08:57 PM
ant996
Defender
Sep 14, 2006 05:03 AM
