Steering box seal kit?
Check this link out. Plenty of options. Seals for $35 or rebuild kit for $85. Keep in mind that it may be leaking because there is excessive play in the bearings. Land Rover Discovery 2 II Power Steering Gear Box Repair Kit QFW100140 New | eBay
Check out the price for a rebuilt or replacement box, too.
The screw is used to adjust the play in the steering box between the input and output shafts. If the output shaft itself has play in it, meaning that it shifts side to side, then you need to deal with that. Check out the section in RAVE. It shows the components within the box in some detail.
Chrisinhouston
01-06-2015 07:00 AM
