Steering box seal kit?
Old Jan 2, 2014 | 02:01 PM
MONEYMIKE's Avatar
Default Steering box seal kit?
04 d2, im looking for a seal kit but cant really find a good one. The dealer was asking about $57 for the top ring and the rings for the lower part where the pit arm is. Do u guys know any good seal kits for a little cheaper. Thanks in advance!
Old Jan 2, 2014 | 06:16 PM
04duxlr's Avatar
Check this link out. Plenty of options. Seals for $35 or rebuild kit for $85. Keep in mind that it may be leaking because there is excessive play in the bearings. Land Rover Discovery 2 II Power Steering Gear Box Repair Kit QFW100140 New | eBay
Check out the price for a rebuilt or replacement box, too.
Old Jan 2, 2014 | 06:36 PM
MONEYMIKE's Avatar
When you mean theres a lot of play in the bearing ... Do mean the bearings need to be replaced or does the adjuster screw need to be tighten or loosened, and how safe is this buy on ebay?
Old Jan 2, 2014 | 07:52 PM
04duxlr's Avatar
The screw is used to adjust the play in the steering box between the input and output shafts. If the output shaft itself has play in it, meaning that it shifts side to side, then you need to deal with that. Check out the section in RAVE. It shows the components within the box in some detail.
Old Jan 2, 2014 | 08:23 PM
MONEYMIKE's Avatar
Alright man thanks for the info, do you know what page in the rave manual.
Chrisinhouston
Jan 6, 2015 07:00 AM
dforrestca
May 19, 2012 09:09 AM
PhxDisco1
Nov 18, 2010 09:57 AM
Darover
Jun 30, 2009 02:37 PM
grussell
May 12, 2009 11:51 AM
