Steering knuckle seperation - how to break the ball joint bond?
Old Nov 15, 2018 | 02:33 AM
twr7cx's Avatar
Question Steering knuckle seperation - how to break the ball joint bond?
Top and bottom ball joint boots have splits in them and given that the vehicle is now 16 years old with 280,000km it's time to replace them. I've stripped it all down now (wheel, brakes, CV shaft off, etc) and just have the knuckle attached to the diff through the ball joints.
What's the hot tips for separating the steering knuckle (i.e. breaking the ball joints tapered/rust bond)?
I'm always weary of the BFH method.
I've tried an air hammer with a ball joint separating fork and a manual one and can't get in very far before the tip of the fork fouls somewhere on the knuckle.
Special separator tool (yes, I know there is a genuine Land Rover one, but is there a more accessible alternative?)? The one I have here for ball joints/tie rod ends seems to be a bit too small.
My pullers, including a decent hydraulic one, just don't seem to able to fit on properly on the bottom ball joint and the top is inaccessible to them.
Old Nov 15, 2018 | 08:21 AM
Alex_M's Avatar
Can you just use a vice or a press like with most universal joints? I've never had that joint apart, but I'd be willing to bet yes.
Old Nov 15, 2018 | 08:22 AM
DiscoBuckeye's Avatar
You have soaked it in penetrating fluid? Applied heat?
Oddly enough the BFH has only worked for me on one vehicle, our D2
Old Nov 15, 2018 | 12:18 PM
Alex_M's Avatar
Jeez, ignore my post. I'd just woken up. For some reason I thought you were talking about the u joints in the steering shaft.
If you're doing ball joints, bfh is the way.
Old Nov 15, 2018 | 01:18 PM
OverRover's Avatar
First, you can buy these tools online or just go to Advance Auto Parts or Autozone and RENT THEM!
To remove the Ball Joints use a "C" style press.... it's your best friend.
> https://www.harborfreight.com/ball-j...les-63279.html
If you don't want to use a BAH or a proper sized pickle fork to remove the Tie Rod Ends, then either of these will work like a champ.
> https://www.tooltopia.com/otc-tools-7315a.aspx
> https://www.bavauto.com/bmw-ball-joi...SABEgKp2_D_BwE
Old Nov 15, 2018 | 07:29 PM
Disco2ct's Avatar
6th Gear
I just did mine two weeks ago. I used a ball joint splitter on the bottom pickle fork on the top a ton of pressure on both and a repeated beating with the BFH! Fun stuff.....not
Old Dec 21, 2018 | 04:17 PM
twr7cx's Avatar
Thanks all for the advise and guidance. Managed to break the taper by swinging a 4.5kg sledge hammer to hit two 4lb mallets that were held on either side of the taper by a second person like anvils. Took a few swings but all four eventually gave in.
jrm123180
Mar 8, 2020 12:33 PM
JettsRover
Nov 2, 2017 01:59 PM
Antmen
Nov 1, 2012 07:27 PM
hevkev
Jan 12, 2009 11:31 PM
Newbie
Nov 13, 2007 09:25 AM
