Steering Wobble
Old Sep 9, 2006 | 06:16 PM
Default RE: Steering Wobble
Where is the diff leaking from? No it won't cause a wobble.
Look around for a shop that does suspension and frame work, someone can check it for you.
Mike
Old Sep 11, 2006 | 01:18 PM
Drnknmnky13's Avatar
My 99 disco II (160k miles) has recently started having this problem as well. It seems to be mainly after hitting a bump so my first thought is shocks. I looked around under the truck and it looks like the bushings are cracked. I looked online for a bushing kit but found nothing for 99 and up IIs.I guess I have to buy each bushing seperatly? The wobble is only in the steering wheel. Any thoughts or suggestions on where to look first?
Old Sep 11, 2006 | 03:57 PM
geoman's Avatar
Drnknmnky13,
Read my sections regarding suspension and steering at www.eurotekapg.com under technical info.
There can be a combination of worn components causing the wobble. Steering dampner, tie-rod ends, and Panhard rod bushings are a few of these.
Regards,
Geoman
eurotek apg
Old Sep 25, 2006 | 10:01 PM
anthonyb's Avatar
I had a wobble at 55mph, got the tires balanced, and it ran smoothly afterward. I had to replace two out of four tires because too much pressure warped them!
good luck mate!
Old Sep 25, 2006 | 11:05 PM
1eyescooter's Avatar
My 96 Disco also has a pretty serious wobble around 50mph, it also wobbles when I hit a hole, the higher the speed the more sreious the wobble. I am going to be getting my tires aligned, but if any of you guys that are experiencing this same problem find another problem area to look at, please tell me so I don't have to get too dirty.
Thanks
Nikki
super90
Jul 31, 2010 06:08 PM
Spencerfitch
Jun 26, 2010 11:02 PM
Rover Chris
Dec 12, 2009 07:53 AM
Clunker
Sep 11, 2008 12:24 PM
stephenibiza
Defender
Dec 2, 2006 05:36 PM
