Stereo Help
Old Feb 28, 2017 | 08:45 AM
  #21
Mstudt's Avatar
Last night I was able to mount the new amp in the glove box, and run the wiring. At this point the rear speakers are done, amp is installed, and all wiring for the head unit and amp is done.
Tonight I'm going to bypass the factory amp, and remove then remove the factory amp. Once this is done I should be able to at least test the rear speakers to make sure I ave the correct wires connected.
I'll be sure to post picture of this when it's completed. I'll also post information on the bypass wires that need to be used. The information I found on here to use was not correct, and I found that out last night.
Old Mar 7, 2017 | 07:29 AM
  #22
Mstudt's Avatar
The stereo project has been moving a little slower than expected. Over the weekend I was able to bypass the amp with no issues. When I was looking to install the front speakers I found out there's no way for my to install the tweeters in the pillar like I hope. That left me with needing to find a good spot for them. I ended up taking the mid's apart, and used those to house the tweeters.
Here's the mid taken apart.
Here's the finished product. I used a 2" hole saw to drill out the center of the screen. It's not as clean as I'd like, but it looks OK.
I'll get the information posted about the bypass, and the different options you have with it in the next couple days.
LR4LIFE
Nov 4, 2007 10:06 AM
Supercam
Jul 11, 2007 09:42 PM
Supercam
Jul 11, 2007 05:43 PM
agentmilo
May 8, 2007 11:43 PM
NightWithTheDisco
Audio/Visual Electronics
Dec 2, 2005 03:20 PM
