still have a problem
Old Mar 5, 2020 | 08:19 AM
Giorgier's Avatar
Default still have a problem
my disco 2 4.0 v8 not working good working with halting flashing check engine light and dont have power obd writes p0306
Old Mar 5, 2020 | 08:29 AM
roverboy40's Avatar
If you haven't done so lately I would start with new plugs. Sounds like a misfire. Then move to new wires (Magnacor recommended), and lastly new coil packs (stick with Bosch). Hopefully this helps.
Old Mar 5, 2020 | 08:46 AM
Giorgier's Avatar
changet but no progres
Old Mar 5, 2020 | 08:54 AM
Best4x4's Avatar
You cleared the P0306 & it came back? If plugs, wires, and coils are new the next step toward a misfire is a bad injector or something wrong with that cylinder.
Old Mar 5, 2020 | 09:04 AM
Giorgier's Avatar
injectors and compressions are good i cant detect reason
Old Mar 5, 2020 | 11:17 AM
mollusc's Avatar
Have you tested for vacuum leaks? Is your coil pack bracket securely bolted to the engine? Are all battery connections clean and secure including grounding connections to the engine and body?
Old Mar 5, 2020 | 07:48 PM
Extinct's Avatar
Stop throwing parts at it and start diagnosing.
Swap plug wires with #6 to another cylinder - see if it follows. Do the same with the plug. Then swap coils left and right. Then swap oxygen sensors left and right. Post your compression readings. Get and ELM327 and android torque app, post the oxygen sensor charts and the MAF sensor charts.
Speak with data, everything else is just bull****.
Matt Brooks
Apr 3, 2019 02:33 PM
big-boss
May 28, 2018 08:47 PM
Akumal
Dec 9, 2012 12:51 PM
Disco Den
Mar 28, 2010 12:42 PM
Scott2747
Feb 8, 2006 12:11 AM
