Still vibrating
The truck is stock height. The tires are fairly new. The truck rides nice and smooth with the front driveshaft removed. When the driveshaft is in, it vibrates thru the floor, I'm sure its something with the front drive assembly. I'll remove the shaft again and check the front end. I feel like I'm driving a station wagon when I don't have my 4x4.
Drive shaft needs to go to a drive line shop which will spin it up to a high rpm.
Or your front diff is wonky.
Can you grab the input of the front diff and can you try to move it even 1mm or less up and down?
Any play in the front diff input?
You need some pros on the drive shaft like these guys.
Heat straightening & balancing a Drive Line - YouTube
some of the online/fleabay scrappers have free shipping on them. I have gotten them from Marty and Paul.
classicroverparts....ky_scrap......i think
that will keep you off your back in boneyard
Dfw area swing by my place. I have 3 proven good ones...$25 ....5gl bucket included
hey..just a comment... I was having a strong vibration in the front of my Disco '01... I rebuild the propeller shafts, both... tire balance ok.. and the vibration continues... then.. I goes into a front ABS sensor problem... I decide to change it....when I took apart the wheel hubs..... both of them was bone dry and the seals are cracked... so I changed... surpise.... the vibration dissapears.... so check your wheel hubs.... you need to take it out and inspect them... if you try to check installed.. you can not see if they are good or bad...
just a comment.. works for my Disco...
domyo
Sep 25, 2008 12:19 PM
