Strange noise in D2
Old Apr 5, 2010 | 03:13 PM
hilltoppersx's Avatar
... not good. drop the shaft and inspect the centering ball, you need to grease the centering ball kit and re-install and hope its not destroyed. that grease it comes with is merely for shipping purposes.
Old Apr 5, 2010 | 04:24 PM
okdiscoguy's Avatar
Originally Posted by Torancis_LR
Hi, I have a TW as well. How exactly do you grease the centering ball?
I have a D1, not really sure. I know you have to drop the shaft, find the fitting and use a needle fitting on a grease gun.
Did your shaft not come with instructions for greasing?
Old Apr 5, 2010 | 05:45 PM
Torancis_LR's Avatar
No instructions, I just learned from the forum to grease the 3 zerks.
Old Apr 5, 2010 | 05:55 PM
discoinchatty's Avatar
Alright, i got the ds out, and the centering ball looks fine. I'll regrease the u-joints along with the centering ball. I'm assuming I should just get some grease around the centering ball and in the socket, that seems to be the only way to grease it. I won't have time to do the tranny flush, the drain screw is rounded out, but I will change out the fluids in the t/case and diffs. For some unknown reason all my local autozone had was dino oil, I know the d2's come stock with synthetic. Will it cause any problems not using synthetic?
Old Apr 5, 2010 | 06:55 PM
okdiscoguy's Avatar
There should be a flat zerk for the centering ball. I don't have one, so I can't take a pic. You will need a needle fitting that goes on the end of a grease gun to get it. Looks kinda like a pencil. Do not just slather grease in there. There is a fitting...
Ok, found this. Right below where #9 is pointing, that is the fitting you need to grease...
Old Apr 5, 2010 | 08:06 PM
I didn't see any kind of fitting like that... How about you Torancis?
I read your reply a little late, I did just slather some grease in there. I took it out for a drive and still no more noise.
I took a quick video of the noise on my way home before it stopped, you'll have to turn the volume up to hear it well.
http://www.youtube.com/watch?v=ldnwQWytmXQ
Old Apr 5, 2010 | 09:32 PM
OMG discoinchatty, that is the exact same sound I am getting in my 04. It happened about a week ago and would sound intermittently.
I was thinking it could be a wheel bearing or some sort b/c I took the truck to a mechanic for my new brake install and the guy was just pounding the front rotors like crazy b/c its rusted and wouldn't come out.
I'm thinking he probably busted some of the bearings.
Other than that, I've just greased my TW 3 days ago. Can't find the grease fitting for the centering ball. I will looking again tomorrow.
Old Apr 6, 2010 | 07:59 AM
you can get the grease gun accessory kit from HF for like $10. It has all the grease fittings you will ever need.
Old Apr 6, 2010 | 08:27 AM
Now that i've listened to it a few more times I think you may be right torancis. Let me know if you find anything out. Has it come back at all since you first heard it?
Old Apr 6, 2010 | 10:13 PM
The sound hasn't come back for the last couple days. I am trying to figure out if it has to do with the warm weather over here.
Lets keep each other updated
adowgiert
Jul 1, 2023 12:06 AM
PaulH
Freelander
Aug 31, 2007 04:43 AM
jodilynne516
Apr 9, 2007 02:52 PM
Ali McAuley
Nov 20, 2006 11:15 AM
Durfee
May 25, 2006 02:21 PM
