Strange noise with engine off
Old Mar 19, 2012 | 01:33 PM
johndreaney's Avatar
Default Strange noise with engine off
I have a strange noise with the engine off. It seems to be coming from the SAI components on the drivers side. It is like a pressure leak almost. A very slight ticking-buzz type sound. Not sure if it is normal or indicative of something going wrong. The sound is very low you have to concentrate to hear it but it definetely seems to be coming from the silver part on the drivers side. Anyone had this before?
Old Mar 19, 2012 | 03:35 PM
schwaggy's Avatar
Drivers side is your ABS modulator.
https://landroverforums.com/forum/di...tor-box-18224/
https://landroverforums.com/forum/di...s-module-6701/
Is your noise coming from this?
Old Mar 20, 2012 | 06:57 AM
Default Not the ABS
No, it is not coming from the ABS - it is coming from the round silver object attached to the exhaust pipes I think. I thought it was part of the SAI system.
Old Mar 20, 2012 | 07:02 AM
Check your hose connections from the valve to the metal lines.
Vai2kdna77
Jun 10, 2013 04:55 PM
DubaiMike
Sep 29, 2009 12:24 AM
nashville rookie
Aug 27, 2008 04:48 PM
meltdowndave
Apr 20, 2008 03:12 PM
