Strange One (transmission)
Old Jul 1, 2008 | 12:47 PM
dewhorse's Avatar
Default Strange One (transmission)
This morning I had a strange one happen, both transmission lights (M &S) were blinking and the LED on the shifter was blinking and I had lost power. As soon as I shut the vehicle down and restart it the lights cleared and it was fine. I know it's a Rover so funny things happen but I need to know if this is an alert for something major or something I can ignore?
Old Jul 1, 2008 | 01:52 PM
bmkraus's Avatar
Default RE: Strange One (transmission)
I too just had this problem only with mine, after i restarted my check engine light came on. Have not had tome to take it to get codes read (will post those when I do). If it sheds any further light on it, I was traveling up hill on the 60 Fwy (between Arizon and California) with temps at 119[:@] Any insight would be greatly appreciated!!!
Old Jul 1, 2008 | 02:01 PM
dewhorse's Avatar
Mine happened from a cold start and the SES light has been on awhile.
Old Jul 1, 2008 | 03:23 PM
Why do you drive around with a check engine light on?????????????????????????
Clean your battery cable and the go get both your fault codes read and have a battery/alternator test done. This will answer it all.
Old Jul 1, 2008 | 03:29 PM
dewhorse's Avatar
I just have not had time to take care of it.....I will do just that......
Old Jul 1, 2008 | 04:32 PM
Not had time!!!!!!!!!!!!!!!!!!!!!!!
So why asking use what to do?????????????????????
Old Jul 1, 2008 | 06:00 PM
bmkraus's Avatar
Didnt drive it after the CEL came on....just had to go straight to work for a double shift. I get off at 4PST and plan on taking it straight to Autozone to have the codes read. I did however check the battery cables and conections....everything seemed on the up and up, no corresion or other mess there and I believe the battery only has about 5K miles on it....although i am planning on switching to a duel yellow top set up like you Mike.
Old Jul 1, 2008 | 09:13 PM
Low voltage can cause this, low tranny fluid too.
You need to get it checked out, any time a light on the dash flashes at you it is serious, the light flashing means "hey dumbass, look at me". Now I am not saying that you are a DA, but you need to get it looked at ASAP.
moparrebellion
Aug 18, 2012 06:53 PM
ljdiscovery
May 16, 2010 02:23 PM
apcollin
Oct 28, 2009 07:10 AM
tuwrx
Mar 26, 2008 07:26 PM
