stuck in gear
Old Apr 4, 2008 | 08:15 PM
jsh's Avatar
jsh
4wd High
Default stuck in gear
Hi guy's:
1996 discovery 95000kms new to me
the vehicle is stuck in drive. I can go down to third but nothing else.
anybody had this problem
thanks
john
Old Apr 4, 2008 | 09:12 PM
Default RE: stuck in gear
Have you tried shifting gears from under the trk?
Have someone set the parking brake and hold their foot on the brake pedal, turn the key on and crawl under the trk, on the side of the trans is a lever that the gear selector connects to, move it by hand and see if it will go through all the gears.
If that works then it is jammed in the console.
You will need to disconnect the gear selector from the trans to check this.
Old Apr 4, 2008 | 10:01 PM
jsh's Avatar
jsh
4wd High
spike:
Turned out to be C clip at the top of the shift lever. used existing one re&re
While console was out (unnecessarily) I swapped the front and back window switches
thanks for the reply
john
HawesEA2
Dec 17, 2016 09:47 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
Lee1140
Dec 1, 2009 10:17 AM
smyevich
Aug 31, 2006 01:31 PM
