stuck in park
Old Aug 21, 2013 | 02:07 PM
dirtlord's Avatar
Default stuck in park
ok i just finshed my head gasket job. the bottom cooler lind popped off. sprayed fluid everywhere. other then that before the job no problems with shifting. no check engin light. could it be bc the tranny is low on fluid it wont go in gear? is the bottom cooler for the tranny? any ideas?
Old Aug 21, 2013 | 02:31 PM
dirtlord's Avatar
ok no brake lights, and the line keep popping off. i think i may have the line fixed. i would research but i have to be out of this house by friday moring. thanks again
Old Aug 21, 2013 | 03:26 PM
dusty1's Avatar
idk, but isn't there a like a position sensor that keeps from shifting without depressing brakes?
Old Aug 21, 2013 | 03:41 PM
weepit's Avatar
Loads of threads here about this, I still have nightmares. Five minutes of searching should give you plenty of info.
If your brake light switch needs replacing it is cheap and easy (which we all love, not just with rovers either).
Old Aug 21, 2013 | 03:43 PM
What hose are you referring t? If you have no brake lights, then your brake switch is broken at the brake pedal, common part that most auto parts store can get you.
Old Aug 21, 2013 | 04:20 PM
caymandrew's Avatar
The bottom cooler is for the gear box. If the brake switch is broken and you're in a bind and have to get it in drive, you can wiggle up the shifter cover in the center counsel, and on the left hand side push in the solenoid keeping it locked in park. Here's a picture:
amer_qureshi
Jul 10, 2024 02:03 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
felixx23
Jun 2, 2005 12:05 AM
