Sump to bell housing bolt torque spec?
Old Aug 9, 2023 | 08:11 PM
neuropathy's Avatar
Default Sump to bell housing bolt torque spec?
I'm following the manual, but the last thing I want to do is crack more of this brittle old aluminum and I can't be sure exactly which spec I should be using.
The sump bolts are clear - 16 lb-ft
The other 6 bolts (2 facing the engine and 4 facing the tailpipe) that attach the sump to the bell housing aren't clear to me - 6 lb-ft?
I don't think the 6 bolts are supposed to be tightened at 16 lb-ft like the sump bolts...
Is it this spec for 6 lb-ft? Oil sump to gearbox housing bolts 8 Nm (6 lbf.ft)
They're mentioned in the disassembly...
but not the reassembly...
Old Aug 10, 2023 | 01:31 PM
dswilly's Avatar
I see 6 # ft. under the auto gearbox section - oil sump to gearbox housing bolts
Old Aug 10, 2023 | 01:54 PM
neuropathy's Avatar
thanks that’s what I was looking for those bolts but wondered if I was looking at the right description and if I should follow that (don’t have a wrench that goes that low anyway) or some other recommendation since I know these leak - trying to just do what I can to keep the oil in there.
Old Aug 10, 2023 | 01:59 PM
dswilly's Avatar
I don't think they seal anything, just secure the pan to the bellhousing. #15 & #17 seal the rear sump seal I think.
Old Aug 10, 2023 | 02:05 PM
neuropathy's Avatar
Thank you - I've got the pickup pipe installed on the new front cover and I'm ready to install the sump - cleaned the sump throughly and the gasket surfaces. I plan to follow the manual, which shows that I need to use globs of sealant (I'll use ultra black) on the ends of the cruciform seals and streak the sealant across the areas where the front cover and the sump meet. I trimmed back the excess sealant and gasket that was sticking out between the engine block and the front cover so the sump will seal better with some sealant and the gasket, hopefully. If there's anything else that's recommended for this like using loctite on all the bolts (not specified in the manual) or using more sealant elsewhere on the surfaces please let me know. There's some pitting on the engine block gasket surface - I'd say it's minor, but I'm not an expert.
Old Aug 10, 2023 | 02:33 PM
dswilly's Avatar
I installed mine exactly as recommended by the RAVE manual and leak free 2+ years later. I would put emphasis on cleaning the surfaces, taking your time installing the pan, torquing it down correctly and making sure your PVC system is working correctly.
Old Aug 10, 2023 | 02:37 PM
neuropathy's Avatar
Thanks, I did the PCV mod and I think it should be working correctly. I'll follow the manual and hopefully it'll all hold together.
Old Aug 10, 2023 | 04:58 PM
gecko951's Avatar
6ft/lbs is just snug it up territory but I do like using my bicycle torque wrench just to verify all the bolts are similarly snug.
Powerbuilt 1/4 inch Drive Ratcheting T-Handle Torque Wrench, 20-100 in. lb. Range Powerbuilt 1/4 inch Drive Ratcheting T-Handle Torque Wrench, 20-100 in. lb. Range
Stephen Perez
Mar 4, 2020 04:26 AM
cvhyatt
Aug 15, 2019 02:42 AM
cobbcj7
Oct 3, 2017 08:25 AM
butchereric
Feb 19, 2015 06:27 PM
golgafrinch
Jan 13, 2015 02:53 PM
