... a sunroof that opens alone...
Old Apr 29, 2012 | 02:22 PM
Hurricane Moon's Avatar
Default ... a sunroof that opens alone...
Could it be possessed?
Hi everyone...
I'm having issues with my sunroof (Disco II, 2004 SE). Sometimes, when I start the engine, I notice the sunroof opening somewhat.
I've been thinking of a possible relay issue, but I need a second opinion or as many a possible.
If anyone has had any experience with issues such as this one, I would greatly appreciate any input,
Thanks
Old Apr 29, 2012 | 04:28 PM
wilson96rr's Avatar
the sunroof has an ecu. it is tan little box up by the sunroof under the headliner. Could be a bad switch also. I would try moving wires around and tapping on stuff up there to try an isolate the problem. The good news is that sunroof ecus and switches are cheap.
Old Apr 29, 2012 | 09:06 PM
The BCU enables the sunroof via a switched wire from the ignition. You could remove fuse F12 inside the truck, which should kill constant un-switched power to the sun roof, and it should stay in one place, unless there are shorts fom other connectors (water, skinned wires, etc). Perhaps that will help you diagnostics. Wiring diagram from RAVE attached
File Type: pdf
Old May 1, 2012 | 06:55 PM
Thank you both for your prompt responses.
I'll look into the schematic in diagnosing it.
Thanks again.
TRIARII
Sights N Sounds
Jan 27, 2014 07:05 AM
populist
Jul 19, 2013 07:09 PM
tulsa
Jun 27, 2010 06:01 PM
discosmurphy
Oct 22, 2008 12:05 AM
