Swap 2003 4.6 with a 2001 4.0
SAI isn’t that bad. As long as the vacuum lines are good, and the pump works it’s not a bad system really. 4.6L vs 4.0L = direct swap as both are SAI.
My current project (that I own) is an 04 that runs super cool, but has a low oil pressure issue at idle. She also smokes a bit under hi revs. It needs to be torn down, but I don’t have the time right now.
Another D2 I am working on for a friend had cylinder 5 misfires even after new wires/plugs/coils were installed. Once it warms up it knocks like it has a stuck lifter, rod, or valve issue & #5 cylinder misfires like crazy. Head gasket isn’t blown out so it’s sick. He just needs a hunting truck, but it’s just another 4.6L with a problem.
