synthetics in the axles
Old Sep 8, 2007 | 03:19 AM
Darover's Avatar
Default synthetics in the axles
Guys, bought some 75w90 full synthetic gear oil today, and will proceed in the axles oil change tomorrow. I'd like to know if it's a simpledrain and refill, or there is something else I should know about since I'm switching to synthetics ???? like do I have to do a flush ???, or just letting it completely drain out for an hour or so is good enough???
Also, the rave CD recommends to change the O ring and nut !!!! Can I re-use the ones that are on now??? or isthe changea must???
Thanks.
Old Sep 8, 2007 | 07:57 AM
Default RE: synthetics in the axles
Your truck came with synthetic in the diffs and t/case, so you'll be fine and as for the fill plugs on the diffs, the plastic ones do tend to brake, I would go to the solid brass replacements that are sold at Expedition Exchange.
Old Sep 8, 2007 | 09:47 AM
Darover's Avatar
All right, so if I read this right, I shouldn't do it until I have replacement plugs because I might be stuck with a broken plug.
Right...
mcleoddude
Oct 13, 2009 11:41 AM
d2luvr
Jun 15, 2009 10:39 AM
okdiscoguy
Mar 12, 2009 02:45 PM
ZstHHS07
Feb 4, 2008 11:12 PM
mowthat
Mar 15, 2007 08:05 PM
