T-case end play...
Old Jun 22, 2007 | 09:41 PM
okdiscoguy's Avatar
Default T-case end play...
Ok,
How much pay is tolerable for the front driveshaft? When I park on a slope and engage the parking brake, I get about 3/16ths of rotation from the front driveshaft (on the diameter of the couplers). I know Rovers have some play, but I was wondering if I needed to replace my front assembly. I have some whine, but if the T-case is in diff-lock or I lightly apply the parking brake, it goes away. I am planning on doing the U-joints on the rear drivshaft......
Thanks,
Jason
Old Jun 23, 2007 | 08:28 AM
Default RE: T-case end play...
Jason,
When put a Disco into park on a hill, a little rotation is normal, I don't think I would loose any sleep over that. As for the whine, still normal, if you want to slow the whine down, changed the gear oil in the t/case switching to a 85W/140 syntheic gear oil, this will give you much better wear protection and quiet the noise down a little.
Mike
Old Jun 24, 2007 | 04:28 PM
okdiscoguy's Avatar
Thanks Mike, I changed over to the 85W140 at the beginning of spring. I had 75W90, but just wanted a little heavier...
I just get nervous about the driveline grenading while I am out..
Old Jun 24, 2007 | 04:57 PM
The only thing that will go puuff on you will be the diffs if you haven't switched to lockers.
Mike
orangechicken
Oct 9, 2014 08:26 AM
xmarksit
Nov 26, 2013 08:37 AM
yoshibond
May 6, 2012 12:18 AM
sharpshooterjohn
Apr 20, 2011 07:11 AM
llPANCHOll
Jul 10, 2009 06:33 AM
