T hose issue 2004 disco
Old Jan 3, 2015 | 09:55 AM
Dpavelock's Avatar
5th Gear
Default T hose issue 2004 disco
Mine fell apart. Want to just replace with another t hose connector without a bleeder. Will that be a problem?
Old Jan 3, 2015 | 10:36 AM
DustyLBottoms's Avatar
Yes, that's a huge problem.
You MUST properly bleed the system, or you're gonna have a bad time. If you don't have the bleed valve, then you'd have to vacuum bleed the system every time you top the coolant off.
Old Jan 3, 2015 | 11:59 AM
Dpavelock's Avatar
5th Gear
Default T-Hose
Thanks - Just ordered the part. Too bad you have to buy the entire assemly
Old Jan 3, 2015 | 02:12 PM
KinverTurtle's Avatar
Default Yep...
Which is why I saved my old T last time I replaced the hoses. I suggest others to do the same if they have the opportunity.
D2 2003
Nov 7, 2017 07:41 AM
Dpavelock
Jan 3, 2015 12:03 PM
Gromeo
Dec 27, 2013 11:57 AM
Sam95disco
Dec 6, 2011 08:52 PM
NhudeST
Apr 26, 2010 06:09 PM
