Tcase stuck in high
Old Jun 26, 2014 | 12:55 PM
ls1morethanyou's Avatar
Old Jun 26, 2014 | 02:19 PM
ralphobell's Avatar
You need to pull your console out again. Take a few photos and post. Did you test it before you put the console all back together?
Old Jun 27, 2014 | 05:51 AM
drowssap's Avatar
I THINK i READ there is one piece of linkage on a D1 shifter that need to be modified, did you do that? I think there is a piece of linkage that has to be re-bent?
Old Jun 27, 2014 | 08:20 AM
Jared9220's Avatar
That is only if you keep the D2 hi/low selector on the T-Case. If you switch over to a D1 hi/low selector and the D1 shifter then you don't need to bend the selector lever because the D1 already had the bend in it. If you just put in the D1 shifter then you have to modify the linkage to fit. I do believe that he installed a new selector and shifter so he should not have to bend anything.
If you buy this piece also with your shifter then you don't need to modify anything.
Old Jun 27, 2014 | 08:56 AM
ralphobell's Avatar
You posted you went wheeling, does that mean you fixed it? If so what was your fix?
Old Jun 27, 2014 | 09:26 AM
No fix yet- stuck in high. No fun.
Probably dropping tcase.
Fishman
May 20, 2014 10:28 PM
ImQuattro
May 1, 2014 08:36 PM
EstorilM
Oct 11, 2011 08:13 PM
anything old
Sep 14, 2010 09:47 PM
brooksa
May 24, 2008 10:40 AM
