Terrafirma MD
Old Sep 4, 2012 | 10:40 PM
  #21
Rover_Hokie's Avatar
Originally Posted by ZGPhoto
No, you installed correctly. It would not change the height either way. Only the fronts can truly be installed incorrectly.
So, tell me how the front should be installed please?
Old Sep 5, 2012 | 08:06 AM
  #22
ZGPhoto's Avatar
The front spring has an extended coil on the bottom that almost screws down to the mount, it's very obvious when you look at the bottom spring mount that it's not flat, and needs the coil to be placed properly.
Old Sep 5, 2012 | 11:04 AM
  #23
coors's Avatar
Just a follow up.
I installed the D1 plates. I gained a little over 3/4" in the rear. Im pleased with the new stance.
I did however end up snapping both driver side bolts that hold down the factory perch plates. Lucky, I had a good bit of threads showing, vice grips, and a little heat from the 'ol ox-actylene torch freed them right up without any effort.
Pics and measurements of new stance to follow.
Old Sep 5, 2012 | 11:05 AM
  #24
coors's Avatar
Originally Posted by Rover_Hokie
Where did you order the D1 coil seats/perches from?
Atlantic British
Old Sep 5, 2012 | 11:28 AM
  #25
drowssap's Avatar
can I assume by this post that if I use Terrafirma MD springs that the truck will not have the correct stance. What is the difference from stock? is the front higher or the rear lower than stock height?
Old Sep 5, 2012 | 01:15 PM
  #26
coors's Avatar
This thread is not to imply that the the Terrafirma MD kit will not make your truck sit correctly.
This is just so happened to be the case for me. Individual results will vary.
However, I can say that the factory rear perch plates on the DII are shallower than the ones on the D 1.
By switching to D 1 the first place you gain 3 quarters of an inch which in my case improved the stance of my ride.
I believe Terrafirma also has a disclaimer stating that the DII may not the chief a full 2 inch lift unlike the D1 with their MD kit.
Old Sep 5, 2012 | 06:47 PM
  #27
kman35ca's Avatar
How much did the perch plates cost?
Old Sep 5, 2012 | 07:08 PM
  #28
coors's Avatar
I think like 16 bucks per plate plus shipping. Check out AB for prices.
FYI
AB refers to them as: rear spring seats
Old Sep 6, 2012 | 09:19 AM
  #29
So when switching to the D1 rear coil spring perch/seat you added the D1 spring retainers as well? My D2 does not have spring retainers on the OEM springs; should it? With the shorter raised area in the middle of the D1 perch that means there is not as much coil springs down around middle section of the perch, is this why the D1 had retainers, and is it recommended to use the retainer if you use the D1 perch?
disco202
Mar 22, 2021 10:06 AM
wheelgarage
May 10, 2012 11:39 PM
jdhuegel1
Mar 1, 2011 08:26 AM
discoboy
Jun 19, 2010 01:35 PM
Fivespddisco
Jun 8, 2010 07:59 PM
