testing the d2 tranny oil light temp sensors
Old Jul 13, 2011 | 07:55 AM
hilltoppersx's Avatar
Default testing the d2 tranny oil light temp sensors
i know there are two one down by the tranny and one up by the radiator. Does anyone know how, if possible, to test to see if they are dead? im sailing all week but Friday I would like to tear into it.
Old Jul 13, 2011 | 08:28 PM
Rovin4life's Avatar
jump the switch connector. it goes open when it goes bad. its not a true sensor with infinite readings. just like a presure switch. Oh and two sensors only, transmission cooler sensor and transfer case.
but here is the trick on getting the sensor out of the cooler if it is bad, pull out the battery and the battery tray, pull out the air box, use a number three philips head bit and eight mm or quarter inch gearwrench or equivalent to fit it and take out the six screws and push the radiator forward, and out, and pull off the fan as well for room and use a 22m wrench that will fit the sensor and take out the sensor and install the new one quick and reinstall everything else and check the level of the transmission when you are done.
Old Jul 13, 2011 | 08:35 PM
dgi 07's Avatar
Rovin, got any numbers for oil pressure sensor? hilltopper and I both threw lights on the same offroad trip.
Old Jul 14, 2011 | 06:23 AM
thanks for the helpful removal instructions, RAVE never gives u those. my stock battery tray is already out so that's a start.
rugbydoc1
Jul 24, 2013 05:18 AM
oljohnboy
Feb 6, 2010 12:49 PM
rrbc
Nov 13, 2009 04:59 PM
shawn
Aug 17, 2007 02:27 PM
