Thermal wrap on catalytic converter
OK I apologize for taking your reply the wrong way. I looked around the interweb and there are some that say its OK and others that say you cant. The disco cat is stainless isn't it? anyway Im going to give it a go AND Ill grease the shaft every oil change, I made sure I bought a shaft with zerks on the ujoints. Anyway before I wrap it Im going to have to keep the pan gasket from leaking all over the place. I replaced the filter and gasket but for some reason its leaking at the rear.
Catco makes a credible copy Y pipe at about $1300, I believe that is made in S/S, but you may be confusing popular Cat back systems on the market by makes such as Borla.
T/V
