Things to replace during longblock install?
Anyone know of any preventative maintenance I should do while I have the whole engine out? I'm swapping in a whole new long block into a 2004 discovery with 90k.
already have a new waterpump and thermostat going in plus new manifold, oil pan gaskets and what not.
DiscoMike suggested a front transmission seal? I forget if that's what its called. Thanks
When I replaced my engine with a used unit, I replaced the valve cover gaskets, rear main seal, and transmission front pump seal (the seal behind the torque converter). The only seal I didn't replace was the timing cover seal because it was bone dry on the replacement engine. It is now seeping.
nychaze
05-14-2013 06:18 PM
Twistid
12-18-2012 11:35 AM
texmbr
01-25-2011 01:19 PM
elboy0712
12-19-2010 02:48 PM
