Things to replace during longblock install?
Old May 30, 2010 | 02:32 PM
rewi9d's Avatar
Default Things to replace during longblock install?
Anyone know of any preventative maintenance I should do while I have the whole engine out? I'm swapping in a whole new long block into a 2004 discovery with 90k.
already have a new waterpump and thermostat going in plus new manifold, oil pan gaskets and what not.
DiscoMike suggested a front transmission seal? I forget if that's what its called. Thanks
Old May 30, 2010 | 03:39 PM
lordmorpheus's Avatar
When I replaced my engine with a used unit, I replaced the valve cover gaskets, rear main seal, and transmission front pump seal (the seal behind the torque converter). The only seal I didn't replace was the timing cover seal because it was bone dry on the replacement engine. It is now seeping.
Old May 30, 2010 | 05:58 PM
Depending on the mileage of your truck, new motor mounts, hoses, belt and change your power steering fluid.
elboy0712
Dec 19, 2010 02:48 PM
EVN137
May 30, 2007 07:24 PM
