Thoughts on "pinning liners"
Old Feb 9, 2013 | 10:26 PM
RoverMasterTech's Avatar
Default Thoughts on "pinning liners"
Wonder If it could be easy as drilling through the side to the sleeve with 5/16 bit and plug welding the hole... thoughts? or drill on an angle under the sleeve and plug weld... thinking of a way to pin them without drilling through them.
Old Feb 9, 2013 | 10:48 PM
BrandonS's Avatar
Maybe I'm not understanding but you would either have an aluminum plug in the steel sleeve or drill into the aluminum block and have a steel plug protruding into that?
Old Feb 10, 2013 | 12:09 AM
willrok13's Avatar
I'm going with a steel "plug" (basically slag built up from the OD of the sleeve?) protruding through the exterior of the block. Interesting idea...
Old Feb 10, 2013 | 04:17 AM
blamo's Avatar
No way the melting point of alm is 1800' I think steel is like 2700' ish you would have a molton mess of alm way before any thing would stick good to the steel ! Just sain blamo.
Old Feb 10, 2013 | 06:32 AM
hilltoppersx's Avatar
no need to reinvent the wheel others have done this.
How to pin liners - DiscoWeb Message Boards
http://www.cardomain.com/ride/235789...vrolet-vega/1/
Old Feb 10, 2013 | 07:21 AM
a different link for pinning with pictures *
spot weld?
Old Feb 10, 2013 | 10:21 AM
BrandonS's Avatar
I'm thinking even if somehow you managed not to melt a giant hole int he aluminum the problem would be that the "fit" of the slag plug would not be exact and have some gaps which could still allow movement since you aren't really fusing the two metals together.
Old Feb 10, 2013 | 11:55 AM
SuperSport's Avatar
How thick are the sleeves? Could you simply drill a hole 1/3 - 1/2 of the way into the sleeve, then thread the Alum and place a Set Screw into the sleeve? Maybe even a couple of them?
willrok13
Mar 5, 2014 02:56 PM
formel3
Aug 16, 2013 05:27 PM
TF10COML
May 15, 2013 08:52 AM
MrFlea1
Mar 21, 2012 12:50 PM
DooFlotchy
Dec 4, 2011 05:09 AM
