The three amigos lights
Ok I just finished flushing the brake fluid and I'll be doing it again after I do the seal swap on the ABS system. I also took the time to remove each caliper/rotor and clean the sensors and they were pretty badly covered in mud and muck from all over the county! I don't know how much of an impact that grime has on the system but it is all clean as a whistle now. I started it a few times and drove around a bit and so far no lights.
Also the fluid was dark red and I was able to replace 1 quart in the system, I don't know how much anyone else normally goes through doing the flush.
